My new 37-116
I don't know the driver transformer looks like to one on mine and I think mine is oem. Nice SET!!!! There a great player too!!!
My new 37-116 - by 37silverstreak - 07-23-2011, 06:31 PM
Re: My new 37-116 - by exray - 07-23-2011, 07:48 PM
Re: My new 37-116 - by etech - 07-23-2011, 08:36 PM
Re: My new 37-116 - by 37silverstreak - 07-23-2011, 10:19 PM
Re: My new 37-116 - by 7estatdef - 07-24-2011, 02:09 PM
Re: My new 37-116 - by Arran - 07-26-2011, 03:37 PM
Re: My new 37-116 - by TA Forbes - 07-27-2011, 11:31 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4273 online users. [Complete List]
» 1 Member(s) | 4272 Guest(s)
