07-03-2006, 04:59 AM
philco fan Wrote:o.k.,got a philco for you guys,hope you can help,picked this up at the c.h.r.s. swap meet yesterday in san francisco,1936 philco 610,first try nothing, found bad 78 and 75 tubes,checked caps,someone replaced the two 8mfd's with 22mfd's,and the 16 with a 22, let the 22 that replaced the 16 alone but replaced the two others with the correct 8mfd's,fired it up again, tubes now lit,plays somewhat distorted and only near 1140 on a.m. band,picks this station up across a wide section of the a.m. band.the first s.w. band sort of works but seems to be picking up a.m. broadcast and the second s.w. band has dead silence.the cabinet has been restored and looks very nice so i'd like to get this one playing well also,any help is appreciated,please remember i'm a novice so if you can dumb down the tech stuff it would really help,i have a sig generator[knight kg650] so i just need to know settings on it so i can trace the signal also what is used for checking the output?,thanks,phil
I've had the same thing happen with a few sets. I'd swear it was the speaker or bad output tube, but not the case both times and more. Keep recapping. My advice is to get familiar with recapping and/or rebuilding the bakelite block units and any others outside of the bakelite blocks if any. You've got the right approach by replacing those bigger caps to a closer value. Maybe it worked but I think it's more likely you replaced a couple of bad capacitors, even though they look to be replaced by the prior owner. Who knows how old they were to begin with. Nice work. Keep on going.
73 de,
Gary/N9VU
