My Hershey car show prize!
Great Finds indeed!! I have seen a few old photographs of 1920's era Radio Stores windows displays on ebay in the past, and noticed the old metal radio stands built back in those days. They look similar in design as the old sewing machine tables/ frames were made ( such as Singer)but were designed for radios and speaker instead. Enjoy your finds!! Icon_thumbup
My Hershey car show prize! - by 37silverstreak - 10-08-2011, 07:22 PM
Re: My Hershey car show prize! - by TA Forbes - 10-08-2011, 09:30 PM
Re: My Hershey car show prize! - by Ron Ramirez - 10-09-2011, 07:41 AM
Re: My Hershey car show prize! - by Marsupial - 10-09-2011, 08:32 AM
Re: My Hershey car show prize! - by Ron Ramirez - 10-09-2011, 01:15 PM
Re: My Hershey car show prize! - by Chicago Jimmy - 10-09-2011, 01:20 PM
Re: My Hershey car show prize! - by Marsupial - 10-09-2011, 08:12 PM
Re: My Hershey car show prize! - by Doug Houston - 10-09-2011, 10:48 PM
Re: My Hershey car show prize! - by Marsupial - 10-10-2011, 12:44 AM
Re: My Hershey car show prize! - by Glenn Roberts - 10-10-2011, 12:35 PM
Re: My Hershey car show prize! - by Texasrocker - 10-10-2011, 12:50 PM
Re: My Hershey car show prize! - by TA Forbes - 10-10-2011, 07:13 PM
Re: My Hershey car show prize! - by Jayce - 10-11-2011, 07:36 PM
Re: My Hershey car show prize! - by PhilcoMike - 10-19-2011, 12:44 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2556 online users. [Complete List]
» 2 Member(s) | 2554 Guest(s)
