10-25-2006, 09:54 PM
Hi, I think that nails the knobs . Makes it a little tricky getting the right ones. But I should be able to now . Today good news and bad news .First the good. Phono came in good shape ! With the speaker. Put 110 v to it and spun it ok . Put needle on ten inch record and could hear it play ! So I think I am under way . There are some small and major differences with this unit and the D10A . First is this is a M4 player and does not appear to fit the cabinet. At least it will not pull out.It is and inch or so wider . So it looks like a stationary shelf will have to be made.Another difference from the D10A isthe m4 takes 6.3 vac to unload the changer. Not a big deal . Plugs are different and a small transfomer will need to be added. I think I can make it go . Turntable is clearly built better than the D10A. Maybe I will run it outboard ! Have a good one ......!
