Questions about model 14 and 17 Chairside radios
Contact Chuck for your 14LZX service info; tell him this is the early 14 that is identical to the late 91, and that you need Bulletin 129-B with any possible revisions/additions.
http://www.philcorepairbench.com/schematics.htm
The later 14 is a completely different radio, so Bulletin 174 will do you no good.
There should be some small numbers at irregular intervals above the AM band frequency markings on the 14LZX; this is for the SW band...unless Philco screwed up and installed the wrong AM-only dial scale (it could have happened). This would be the same dial scale as used on the later 14, the 17, the early 18 with AM and low SW...and the late versions of the 91 which also have a three position off-on-band switch.
