New Project - 39-55
I pulled the chassis and right away noticed that one of the candohm resistors was fried (#41). Looked like it might have caught fire from all the black crap around the burned area.
I pulled the candohm out this is what it looked like:
[Image: http://i1129.photobucket.com/albums/m501...940c77.jpg]
Took it apart cause I was curious:
[Image: http://i1129.photobucket.com/albums/m501...15368e.jpg]
I replaced the candohm with another I had from a junk chassis ( I know. I probably should just replace it with modern power resistors.). Then I started the re-wire job there was no way I was going to power this thing up with all that nasty rubber wire. Whoever worked on it last wasnt to carefull and there was a lot of exposed wire where the rubber has flaked off so I skipped the testing phase and jumped to re-wire. A couple caps have been replaced and 2 e-caps re-stuffed along with some of the wiring at the time these pics were taken.
[Image: http://i1129.photobucket.com/albums/m501...bcc624.jpg]
[Image: http://i1129.photobucket.com/albums/m501...479f61.jpg]
[Image: http://i1129.photobucket.com/albums/m501...756af6.jpg]
That big freaking mess with the more modern e-caps and the resistors was a previous repair not my doing. I had to replace the octal socket for the 6J8 OSC/DET tube. The socket was cracked and socket 3 was pushing through the back of the socket. Luckly I had a spare from that junk chassis I got the candohm from (40-205).
-Keith
New Project - 39-55 - by ipwizard - 02-28-2012, 03:26 PM
RE: New Project - 39-55 - by codefox1 - 02-28-2012, 03:40 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 03:46 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 03:45 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 04:00 PM
RE: New Project - 39-55 - by Glenn Roberts - 02-28-2012, 04:45 PM
RE: New Project - 39-55 - by Bob Andersen - 02-28-2012, 06:02 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 06:06 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 06:13 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 06:17 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 07:01 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 07:11 PM
RE: New Project - 39-55 - by codefox1 - 02-28-2012, 10:23 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 10:43 PM
RE: New Project - 39-55 - by codefox1 - 02-29-2012, 12:31 AM
RE: New Project - 39-55 - by ipwizard - 02-29-2012, 11:32 PM
RE: New Project - 39-55 - by codefox1 - 03-01-2012, 06:04 AM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 05:37 PM
RE: New Project - 39-55 - by Arran - 03-06-2012, 08:14 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 06:04 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 10:27 PM
RE: New Project - 39-55 - by Arran - 03-09-2012, 11:52 PM
RE: New Project - 39-55 - by codefox1 - 03-06-2012, 08:34 PM
RE: New Project - 39-55 - by Bob Andersen - 03-06-2012, 11:03 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 11:21 PM
RE: New Project - 39-55 - by ipwizard - 03-07-2012, 12:42 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 07:51 AM
RE: New Project - 39-55 - by ipwizard - 03-10-2012, 10:59 AM
RE: New Project - 39-55 - by Arran - 03-10-2012, 08:15 PM
RE: New Project - 39-55 - by ipwizard - 03-11-2012, 12:45 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 07:38 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 09:51 AM
RE: New Project - 39-55 - by w4rtc - 03-11-2012, 10:03 AM
RE: New Project - 39-55 - by ipwizard - 04-06-2012, 12:04 AM
RE: New Project - 39-55 - by ipwizard - 04-11-2012, 12:10 AM
RE: New Project - 39-55 - by ipwizard - 04-13-2012, 12:47 AM
RE: New Project - 39-55 - by codefox1 - 04-13-2012, 01:11 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
