New Project - 39-55
Nice job on the power transformer and good luck with the rest Icon_thumbup
I have the same chassis plus mystery control but no cabinet for the radio. I was thinking of leaving it out in the open to demonstrate how the mystery control works. Of course, I need to actually get it working first.
New Project - 39-55 - by ipwizard - 02-28-2012, 03:26 PM
RE: New Project - 39-55 - by codefox1 - 02-28-2012, 03:40 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 03:46 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 03:45 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 04:00 PM
RE: New Project - 39-55 - by Glenn Roberts - 02-28-2012, 04:45 PM
RE: New Project - 39-55 - by Bob Andersen - 02-28-2012, 06:02 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 06:06 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 06:13 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 06:17 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 07:01 PM
RE: New Project - 39-55 - by Ron Ramirez - 02-28-2012, 07:11 PM
RE: New Project - 39-55 - by codefox1 - 02-28-2012, 10:23 PM
RE: New Project - 39-55 - by ipwizard - 02-28-2012, 10:43 PM
RE: New Project - 39-55 - by codefox1 - 02-29-2012, 12:31 AM
RE: New Project - 39-55 - by ipwizard - 02-29-2012, 11:32 PM
RE: New Project - 39-55 - by codefox1 - 03-01-2012, 06:04 AM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 05:37 PM
RE: New Project - 39-55 - by Arran - 03-06-2012, 08:14 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 06:04 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 10:27 PM
RE: New Project - 39-55 - by Arran - 03-09-2012, 11:52 PM
RE: New Project - 39-55 - by codefox1 - 03-06-2012, 08:34 PM
RE: New Project - 39-55 - by Bob Andersen - 03-06-2012, 11:03 PM
RE: New Project - 39-55 - by ipwizard - 03-06-2012, 11:21 PM
RE: New Project - 39-55 - by ipwizard - 03-07-2012, 12:42 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 07:51 AM
RE: New Project - 39-55 - by ipwizard - 03-10-2012, 10:59 AM
RE: New Project - 39-55 - by Arran - 03-10-2012, 08:15 PM
RE: New Project - 39-55 - by ipwizard - 03-11-2012, 12:45 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 07:38 AM
RE: New Project - 39-55 - by Ron Ramirez - 03-11-2012, 09:51 AM
RE: New Project - 39-55 - by w4rtc - 03-11-2012, 10:03 AM
RE: New Project - 39-55 - by ipwizard - 04-06-2012, 12:04 AM
RE: New Project - 39-55 - by ipwizard - 04-11-2012, 12:10 AM
RE: New Project - 39-55 - by ipwizard - 04-13-2012, 12:47 AM
RE: New Project - 39-55 - by codefox1 - 04-13-2012, 01:11 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
