Philco 39-30 restoration
Maybe the pushbuttons are out of whack because the IF alignment is off, not to surprising given the age of the set and the fact that you had to open up one of the cans to replace the wires and a resistor.
Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 12:39 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-27-2012, 01:20 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-27-2012, 11:22 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 02-28-2012, 05:50 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-28-2012, 05:11 PM
RE: Philco 39-30 restoration - by Arran - 02-29-2012, 01:30 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 08:59 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 02:55 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 05:08 PM
RE: Philco 39-30 restoration - by Arran - 03-02-2012, 11:23 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 01:26 AM
RE: Philco 39-30 restoration - by Arran - 03-04-2012, 02:04 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 02:47 AM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-04-2012, 07:28 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 03:11 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 09:13 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-05-2012, 10:47 PM
RE: Philco 39-30 restoration - by Arran - 03-05-2012, 11:53 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 12:40 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 02:45 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 04:30 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 08:09 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 11:42 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-13-2012, 07:17 PM
RE: Philco 39-30 restoration - by Arran - 03-13-2012, 10:08 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-16-2012, 10:45 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-30-2012, 09:05 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-30-2012, 09:08 PM
RE: Philco 39-30 restoration - by Arran - 03-30-2012, 09:50 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-06-2012, 05:11 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 04-06-2012, 08:22 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-06-2012, 11:44 PM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 01:21 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 02:09 AM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 02:20 AM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 08:01 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 03:31 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 05:09 PM
Re: Philco 39-30 restoration - by codefox1 - 02-05-2012, 05:12 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 05:36 PM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 09:40 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-07-2012, 11:18 PM
Re: Philco 39-30 restoration - by codefox1 - 02-08-2012, 10:06 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 05:15 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 05:42 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 05:50 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 08:11 PM
Re: Philco 39-30 restoration - by RGallahue - 02-08-2012, 08:27 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 10:18 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-10-2012, 12:03 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5333 online users. [Complete List]
» 1 Member(s) | 5332 Guest(s)
