Philco 90 Filter Cap Can Question?
Hello, yes, copper "mershon" caps were on the Philco 90 sets. Most of them have since been replaced by other varieties.
On the model 90 with a single 47 output tube, one mershon negative side is chassis ground, but the other one is not. There is a special gasket and copper base for this, with an insulated grommet that passes through the chassis for the negative side of the mershon. The ~1/4 inch hole between one of the electrolytics and the 27 tube is where this would go. If you intend to re-stuff the mershons, this is important.
If they are there for looks, then it is not an issue.
Philco 90 Filter Cap Can Question? - by Pepperoni - 03-10-2012, 05:13 PM
RE: Philco 90 Filter Cap Can Question? - by TA Forbes - 03-10-2012, 10:40 PM
