When Is A Restoration Really A Restoration?
I did some searching and found a great source for radio backs. He has many, many in stock and will do custom work like I need for my console. Name is Retro-Tronics. Here: http://www.retro-tronics.com/index.php What a unique and great service that will help bring back many radios to their former glory!
RE: When Is A Restoration Really A Restoration? - by Sam samuelian - 04-04-2012, 05:08 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3908 online users. [Complete List]
» 1 Member(s) | 3907 Guest(s)
