Am I Missing Something On This Philco 89?
Thanks tab! Very interesting. And on that octal socket Arran It's the 75 tube that was changed to a 6Q7. Don't ask me why I'm just trying to gather info on this set before I start on it. I already have a 6 pin socket on it's way but I haven't ordered the 75 tube yet. Kind of glad I didn't after reading the story that tab put there. I may have to put some real work into this one.
Sure would like to see what one of those brackets looks like that the original filter caps were on. I could probably make one.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
RE: Am I Missing Something On This Philco 89? - by Pepperoni - 04-05-2012, 08:12 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
