Philco 39-30 restoration
#50
WOW...that cabinet shure is PURTY. Icon_thumbup
Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 12:39 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-27-2012, 01:20 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-27-2012, 11:22 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 02-28-2012, 05:50 AM
RE: Philco 39-30 restoration - by Bob Andersen - 02-28-2012, 05:11 PM
RE: Philco 39-30 restoration - by Arran - 02-29-2012, 01:30 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 08:59 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 02:55 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-02-2012, 05:08 PM
RE: Philco 39-30 restoration - by Arran - 03-02-2012, 11:23 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 01:26 AM
RE: Philco 39-30 restoration - by Arran - 03-04-2012, 02:04 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 02:47 AM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-04-2012, 07:28 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 03:11 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-04-2012, 09:13 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-05-2012, 10:47 PM
RE: Philco 39-30 restoration - by Arran - 03-05-2012, 11:53 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 12:40 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 02:45 AM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 04:30 AM
RE: Philco 39-30 restoration - by Arran - 03-06-2012, 08:09 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-06-2012, 11:42 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-13-2012, 07:17 PM
RE: Philco 39-30 restoration - by Arran - 03-13-2012, 10:08 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-16-2012, 10:45 PM
RE: Philco 39-30 restoration - by Bob Andersen - 03-30-2012, 09:05 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 03-30-2012, 09:08 PM
RE: Philco 39-30 restoration - by Arran - 03-30-2012, 09:50 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-06-2012, 05:11 PM
RE: Philco 39-30 restoration - by Ron Ramirez - 04-06-2012, 08:22 PM
RE: Philco 39-30 restoration - by Bob Andersen - 04-06-2012, 11:44 PM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 01:21 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 02:09 AM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 02:20 AM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 08:01 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 03:31 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-05-2012, 05:09 PM
Re: Philco 39-30 restoration - by codefox1 - 02-05-2012, 05:12 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-05-2012, 05:36 PM
Re: Philco 39-30 restoration - by Arran - 02-05-2012, 09:40 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-07-2012, 11:18 PM
Re: Philco 39-30 restoration - by codefox1 - 02-08-2012, 10:06 AM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 05:15 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 05:42 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 05:50 PM
Re: Philco 39-30 restoration - by Ron Ramirez - 02-08-2012, 08:11 PM
Re: Philco 39-30 restoration - by RGallahue - 02-08-2012, 08:27 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-08-2012, 10:18 PM
Re: Philco 39-30 restoration - by Bob Andersen - 02-10-2012, 12:03 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3904 online users. [Complete List]
» 1 Member(s) | 3903 Guest(s)
