Philco 90 Tube Shield Question
Mine is the type with the single 47 tube and the chassis does have the holder for that shield.
- Geoff
Philco 90 Tube Shield Question - by Geoff - 04-09-2012, 02:13 PM
RE: Philco 90 Tube Shield Question - by tab10672 - 04-09-2012, 03:41 PM
RE: Philco 90 Tube Shield Question - by rghines1 - 04-09-2012, 05:37 PM
RE: Philco 90 Tube Shield Question - by Geoff - 04-09-2012, 05:51 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2213 online users. [Complete List]
» 2 Member(s) | 2211 Guest(s)
