Philco Model 20 distortion
The mica cap is on the last 24's plate (detector). A 250pF.
Philco Model 20 distortion - by 93foxconvert - 04-15-2012, 10:34 PM
RE: Philco Model 20 distortion - by 7estatdef - 04-16-2012, 08:17 AM
RE: Philco Model 20 distortion - by morzh - 04-16-2012, 12:42 PM
RE: Philco Model 20 distortion - by Chuck Schwark - 04-16-2012, 01:18 PM
RE: Philco Model 20 distortion - by morzh - 04-16-2012, 03:19 PM
RE: Philco Model 20 distortion - by 93foxconvert - 05-06-2012, 12:21 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 1950 online users. [Complete List]
» 3 Member(s) | 1947 Guest(s)
