1935 model 18 trim color
Light Tan.
1935 model 18 trim color - by tab10672 - 04-30-2012, 10:53 PM
RE: 1935 model 18 trim color - by TA Forbes - 05-01-2012, 01:30 PM
RE: 1935 model 18 trim color - by tab10672 - 05-01-2012, 04:54 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 3016 online users. [Complete List]
» 2 Member(s) | 3014 Guest(s)
