Philco 77 volume control
I doubt if you'll find a 1750 ohm rheostat. I wouldn't be afraid to try 1800 or even 2000 ohms.
Philco 77 volume control - by kenlew0405 - 04-21-2012, 09:55 PM
RE: Philco 77 volume control - by murf - 04-21-2012, 10:14 PM
RE: Philco 77 volume control - by kenlew0405 - 04-21-2012, 11:04 PM
RE: Philco 77 volume control - by 7estatdef - 04-23-2012, 09:25 PM
RE: Philco 77 volume control - by 7estatdef - 04-29-2012, 06:50 PM
RE: Philco 77 volume control - by kenlew0405 - 05-01-2012, 01:32 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 03:05 PM
RE: Philco 77 volume control - by Ron Ramirez - 05-01-2012, 04:02 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 04:41 PM
RE: Philco 77 volume control - by kenlew0405 - 05-01-2012, 04:59 PM
RE: Philco 77 volume control - by morzh - 05-01-2012, 05:07 PM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 07:16 AM
RE: Philco 77 volume control - by morzh - 05-01-2012, 05:33 PM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 07:15 AM
RE: Philco 77 volume control - by 7estatdef - 05-01-2012, 07:19 PM
RE: Philco 77 volume control - by Ron Ramirez - 05-02-2012, 07:25 AM
RE: Philco 77 volume control - by morzh - 05-02-2012, 07:57 AM
RE: Philco 77 volume control - by Ron Ramirez - 05-02-2012, 08:04 AM
RE: Philco 77 volume control - by kenlew0405 - 05-02-2012, 03:05 PM
RE: Philco 77 volume control - by morzh - 05-02-2012, 03:45 PM
RE: Philco 77 volume control - by kenlew0405 - 05-16-2012, 02:51 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5069 online users. [Complete List]
» 2 Member(s) | 5067 Guest(s)
