Philco 32 question
Should be 5-pin socket. Have they rewired it?
Philco 32 question - by TA Forbes - 05-02-2012, 11:09 AM
RE: Philco 32 question - by morzh - 05-02-2012, 11:29 AM
RE: Philco 32 question - by TA Forbes - 05-03-2012, 08:34 AM
RE: Philco 32 question - by Ron Ramirez - 05-03-2012, 09:12 AM
RE: Philco 32 question - by morzh - 05-03-2012, 01:37 PM
RE: Philco 32 question - by Ron Ramirez - 05-03-2012, 06:54 PM
RE: Philco 32 question - by TA Forbes - 05-03-2012, 07:38 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
