Philco bakelite condenser 4989 Z?
Ron,
Thanks for the information.
Chris
Philco bakelite condenser 4989 Z? - by Philcofan - 05-06-2012, 02:33 PM
RE: Philco bakelite condenser 4989 Z? - by Philcofan - 05-06-2012, 06:14 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2603 online users. [Complete List]
» 2 Member(s) | 2601 Guest(s)
