06-01-2012, 11:48 AM
I have been using readily available "power Point" cartridges in my 1201s. They have adequate output and fidality for the cabinet and small speaker in them. You will need to purchase a mount for it also.
The lighter weight is better on records also but you might have to adjust the counter weight spring if it doesn't track heavy enough in the cancel grooves to shut the machine off at record end.
I never had that problem but just making you aware of the possability.
Good Luck
Good Luck
