Threads: 55
City: Claremont, NH
OK, Moving right along....purchased some oil paints and mixed up a pretty close match (I think) for the base. Need to allow it to dry thoroughly and then add in the graining. I'll see how it turns out and if I will have to redo it again. I am hoping not.
[Image: http://i1185.photobucket.com/albums/z345...inted4.jpg]
[Image: http://i1185.photobucket.com/albums/z345...inted3.jpg]
[Image: http://i1185.photobucket.com/albums/z345...inted2.jpg]
[Image: http://i1185.photobucket.com/albums/z345...inted1.jpg]
[Image: http://i1185.photobucket.com/albums/z345...ainted.jpg]
[Image: http://i1185.photobucket.com/albums/z345...M_0026.jpg]
Gene
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM |
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
