They finally arrived!
The two Philco's I purchased at Kutztown back in May finally got to AZ.
First is a 38-15. The set is in pretty good condition needs a lot of cleaning and appear to be untouched except for the added Radio/Phono adapter.
Pics:
[Image: http://i1129.photobucket.com/albums/m501...99f9c2.jpg]
[Image: http://i1129.photobucket.com/albums/m501...b873ff.jpg]
[Image: http://i1129.photobucket.com/albums/m501...8b3003.jpg]
[Image: http://i1129.photobucket.com/albums/m501...ed8660.jpg]
-Keith
They finally arrived! - by ipwizard - 06-30-2012, 02:58 PM
RE: They finally arrived! - by ipwizard - 06-30-2012, 03:02 PM
RE: They finally arrived! - by Michael Gerber - 06-30-2012, 04:18 PM
RE: They finally arrived! - by Paul Philco322 - 06-30-2012, 06:53 PM
RE: They finally arrived! - by TA Forbes - 07-02-2012, 03:58 PM
RE: They finally arrived! - by jerryhawthorne - 07-06-2012, 01:32 PM
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 2997 online users. [Complete List]
» 2 Member(s) | 2995 Guest(s)
