model 86 fm detector problems
Thanks to Don Lind for his suggestions re- the ratio detector coil. I took it apart and found that the slugs were intact and did move up and down. I checked for an internal cap and there was one on the secondary only. It showed no capacitance whatsoever with the coil unsoldered. I cut it out of the circuit and carefully reassembled the can. I had no idea what value of cap to use in the secondary circuit. I dug into my stock of small mica caps and came up with a 47pf unit which I soldered in. I was now able to do a proper alignment and the secondary adjustment does not show a null. The radio now plays distortion free. Thanks again for everyone's suggestions.
model 86 fm detector problems - by daddydonn - 06-13-2012, 07:29 AM
RE: model 86 fm detector problems - by codefox1 - 06-13-2012, 01:14 PM
RE: model 86 fm detector problems - by daddydonn - 06-13-2012, 03:28 PM
RE: model 86 fm detector problems - by daddydonn - 06-25-2012, 08:56 PM
RE: model 86 fm detector problems - by 7estatdef - 06-26-2012, 03:36 PM
RE: model 86 fm detector problems - by daddydonn - 06-27-2012, 08:54 AM
RE: model 86 fm detector problems - by Don Lind - 06-27-2012, 03:08 PM
RE: model 86 fm detector problems - by daddydonn - 06-27-2012, 04:19 PM
RE: model 86 fm detector problems - by daddydonn - 07-05-2012, 12:25 PM
RE: model 86 fm detector problems - by daddydonn - 07-05-2012, 12:28 PM
