Cone sentric tuning questions
Is there enough friction on yours to tune normally. I would like the vernier function for careful tuning on SW. as well. I know a friend that has a 38-4. I may go look at his.
Cone sentric tuning questions - by tubadon40 - 07-06-2012, 09:42 PM
RE: Cone sentric tuning questions - by FXpert - 07-07-2012, 06:20 AM
RE: Cone sentric tuning questions - by tubadon40 - 07-07-2012, 11:48 AM
RE: Cone sentric tuning questions - by tubadon40 - 07-07-2012, 06:27 PM
RE: Cone sentric tuning questions - by tubadon40 - 07-09-2012, 04:06 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 1868 online users. [Complete List]
» 3 Member(s) | 1865 Guest(s)
