Starting on Philco 111 More Questions & Pics
#34
TA, sorry but I was typing my response while you sent in your next. To clarify things a bit about the buss wires on the big can. I do believe (with all respect) that you may be in error on the two buses going to pin 11. According to my schematic, pin 11 goes to ground and has 5 of the caps going to it. The other bus goes to pin 3 (connected under the box to 5) and picks up more caps. This bus goes to the center tap of the transformer.
I will check to see if all is well. The cap block diagram on the schematic shows pretty much what I did.
As for the caps, well Chuck indicated "poly" worked best. Therefore I used Solen Fast caps. Non polarized 2.3 mfd. I can certainly change them to polarized if you feel that would be necessary. I'm really a "dim bulb" on this stuff.
Appreciate you help. Jerry
PS: Failed to respond to a couple of your points. I did check coils for resistance, not having a value to go for but all looked reasonable. Wiggled the tubes around and even did some swapping, to no avail.
RE: Starting on Philco 111 - by Ron Ramirez - 08-14-2012, 04:41 AM
RE: Starting on Philco 111 - by Phlogiston - 08-14-2012, 09:01 AM
RE: Starting on Philco 111 - by jerryhawthorne - 08-14-2012, 01:45 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-14-2012, 02:58 PM
RE: Starting on Philco 111 - by Phlogiston - 08-14-2012, 04:54 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-14-2012, 07:19 PM
RE: Starting on Philco 111 - by Chuck Schwark - 08-14-2012, 09:23 PM
RE: Starting on Philco 111 - by codefox1 - 08-14-2012, 10:41 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-15-2012, 12:02 AM
RE: Starting on Philco 111 - by Chuck Schwark - 08-15-2012, 08:20 AM
RE: Starting on Philco 111 - by jerryhawthorne - 08-15-2012, 01:59 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-17-2012, 06:01 PM
RE: Starting on Philco 111 - by 7estatdef - 08-17-2012, 06:28 PM
RE: Starting on Philco 111 - by Phlogiston - 08-17-2012, 07:20 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-17-2012, 09:31 PM
RE: Starting on Philco 111 - by Phlogiston - 08-17-2012, 10:30 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-18-2012, 08:37 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-19-2012, 09:25 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-20-2012, 06:28 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-21-2012, 12:01 AM
RE: Starting on Philco 111 - by 7estatdef - 08-21-2012, 07:05 AM
RE: Starting on Philco 111 - by TA Forbes - 08-21-2012, 10:26 AM
RE: Starting on Philco 111 - by jerryhawthorne - 08-22-2012, 01:57 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-24-2012, 03:34 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-24-2012, 10:28 PM
RE: Starting on Philco 111 - by codefox1 - 08-25-2012, 10:42 AM
RE: Starting on Philco 111 - by TA Forbes - 08-27-2012, 01:17 PM
RE: Starting on Philco 111 - by jerryhawthorne - 08-28-2012, 04:06 PM
RE: Starting on Philco 111 More Questions & Pics - by jerryhawthorne - 08-28-2012, 11:05 PM
