09-06-2012, 12:20 PM
I can now get 750 or 680 but it has to be tuned to the freq not through the tunner. I added the 100' you suggested. I'm concerned about the other coil the first number I gave for resistance (2.6k ohms) which was wrong the coil measures 850ohms which I think is wrong. Let me explain. The coils were the same physical size and the wire size is the same #37 or .0045" looks like a dog bone (coil on each end) mounted on a ceramic plate which as the trimmers on the other side. well the coil I wound is only about 30ohms using the data I took # of turns and wire size, well by my wire chart for #37 the resistance is 512ohms per 1000' which is a H**l of a lot of wire. so I'm thinking of rewinding that one too?
