Know model number now another question
Thanks guys, with my hearing problems I would probably not notice much difference. My 112 late model with the 47s sounds good to me. The 111 with 45s sounds nice as well. But my hearing sucks! Don't call me on a telephone, I hate it. As for cabinet design, my 112 lacks what I like in something let's say traditional. I like the turned legs. Matches our decor a little better. The 90 captures the look of the 111, other than shorter legs (OK) and lack of closing doors, which is also OK. Arran if you want a 112, let me know. I could always buy another 111 somewhere. Shipping would be a expensive.
Jerry
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3375 online users. [Complete List]
» 2 Member(s) | 3373 Guest(s)
