Another Volume Control Question
OK stupid question, but I will ask anyway.
The on/off/volume control has 3 connectors on the top and 2 on the back face.
I am assuming you are talking about the "outside" connectors of the 3 on top.
I am assuming that the 2 connectors on the back face are for the on/off switch part.
Additionally, when you say
Quote:disconnecting one end
, I am assuming you mean disconnect the wires on one of the outside connectors, but it is ok to leave the other wires connected. Is this correct ?
As far as measing the resistance, what am I looking for, if it is bad ?
Another Volume Control Question - by winkydink - 11-20-2012, 10:23 AM
RE: Another Volume Control Question - by codefox1 - 11-20-2012, 11:20 AM
RE: Another Volume Control Question - by winkydink - 11-20-2012, 10:54 PM
RE: Another Volume Control Question - by codefox1 - 11-21-2012, 11:08 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
