Capacitor substitution
I'd go with the .001, close enough.
Dennis
Pacing the cage...
Capacitor substitution - by winkydink - 12-07-2012, 09:53 AM
RE: Capacitor substitution - by Conelrad - 12-07-2012, 10:43 AM
RE: Capacitor substitution - by TA Forbes - 12-07-2012, 01:24 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5323 online users. [Complete List]
» 1 Member(s) | 5322 Guest(s)
