Model 20 Wiring
I finally finished recapping the filter caps and had to scrape and eventually burn out some of the tar to get the 630v caps in the can. I probably didn't need to use 630v but since the originals were rated at 1200, which I thought was an overkill, I didn't think they'd pose much of a problem other than fit. The 1.5 uf was of course the largest but, I got all of them in, did some rewiring due to the old wires being brittle and green looking.
I replaced the two 71A output tubes and the detector tube and hooked up a 20 ga wire for the antenna but no ground. It pulled in quite a few station just sitting on the work bench and the only problem is a slight hum between where no stations are and a fairly loud crack when you turn it off. Other than that, I'm pleased with it. All filter and bypass capacitors were replaced as were all resistors. I had done most of that before. It's playing better than ever other than the above.
Model 20 Wiring - by Elijah - 12-21-2012, 02:39 PM
RE: Model 20 Wiring - by 7estatdef - 12-21-2012, 06:35 PM
RE: Model 20 Wiring - by Elijah - 12-21-2012, 06:49 PM
RE: Model 20 Wiring - by morzh - 12-21-2012, 08:04 PM
RE: Model 20 Wiring - by Elijah - 12-21-2012, 08:18 PM
RE: Model 20 Wiring - by TA Forbes - 12-21-2012, 11:56 PM
RE: Model 20 Wiring - by morzh - 12-22-2012, 01:42 PM
RE: Model 20 Wiring - by Elijah - 12-22-2012, 02:55 PM
RE: Model 20 Wiring - by codefox1 - 12-23-2012, 01:34 AM
RE: Model 20 Wiring - by Elijah - 12-23-2012, 01:50 PM
RE: Model 20 Wiring - by 7estatdef - 12-24-2012, 02:45 PM
RE: Model 20 Wiring - by Elijah - 12-24-2012, 06:30 PM
