Philco Not Restored as Indicated in Ad
At least you caught it right away.
The description was misleading. I would think that one would VERIFY the condition before posting it with that description.
Personally, I am dubious of the seller's explanation.
My advice to ANYONE buying a "restored" set from anyone or any site is to immediately take the set out of the cabinet and VERIFY!!!
If you run into a situation like the one above bring it to the attention of the seller.
AND posting it here is a good idea, to warn others about possible shysters.
RE: Philco Not Restored as Indicated in Ad - by TA Forbes - 12-24-2012, 09:15 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
