1936? model 84 resistor
Hi! Fired the 84 up to check it out for voltages, & got mixed results.
The plate on the det./osc is 270---should be 240.
Plate on 2nd det. is 68---should be 70--close enough.
Grid 2 on det./osc is 127---service literature doesn't give voltage.
Grid2 on 2nd det. is 51---again no voltage given.
These voltages are from power supply neg.
Voltage from grid 3 to cathode is 23 volts on osc.
Variac is 115 volts in. The 42 output is apparently working--touching grid cap on 2nd detector gives loud 60 cycle
from speaker. Can't test the 77 on my B&K727, but I suspect a bad tube on the osc. Don't get any response
when touching the grid cap on the 77 det./ osc. Any ideas are welcome. Thanks. Jim
1936? model 84 resistor - by brownie45 - 01-22-2013, 02:48 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-22-2013, 06:30 PM
RE: 1936? model 84 resistor - by brownie45 - 01-22-2013, 08:10 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-26-2013, 08:30 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 09:02 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 09:03 AM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 01:50 PM
RE: 1936? model 84 resistor - by codefox1 - 01-26-2013, 02:18 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 06:19 PM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 08:04 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 08:10 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-26-2013, 08:10 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-26-2013, 08:12 PM
RE: 1936? model 84 resistor - by brownie45 - 01-26-2013, 09:41 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-27-2013, 08:59 AM
RE: 1936? model 84 resistor - by brownie45 - 01-28-2013, 03:55 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-28-2013, 10:48 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 06:38 AM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-29-2013, 09:52 AM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 01:40 PM
RE: 1936? model 84 resistor - by klondike98 - 01-29-2013, 02:00 PM
RE: 1936? model 84 resistor - by Ron Ramirez - 01-29-2013, 02:16 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 02:26 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-29-2013, 04:37 PM
RE: 1936? model 84 resistor - by brownie45 - 01-29-2013, 05:39 PM
RE: 1936? model 84 resistor - by 7estatdef - 01-29-2013, 07:48 PM
RE: 1936? model 84 resistor - by brownie45 - 02-01-2013, 02:49 PM
RE: 1936? model 84 resistor - by brownie45 - 02-01-2013, 03:37 PM
RE: 1936? model 84 resistor - by 7estatdef - 02-01-2013, 10:00 PM
RE: 1936? model 84 resistor - by brownie45 - 02-02-2013, 07:10 AM
RE: 1936? model 84 resistor - by 7estatdef - 02-03-2013, 09:07 PM
RE: 1936? model 84 resistor - by brownie45 - 02-04-2013, 07:01 AM
RE: 1936? model 84 resistor - by 7estatdef - 02-04-2013, 09:00 AM
RE: 1936? model 84 resistor - by brownie45 - 02-04-2013, 10:19 AM
