Cracked veneer suggestions
This happens all too often. You can hide the problem by mixin up a little artist'soil paints and use a n old fashioned "spotting" brush like they used to use to retouch negatives. A couple of "values" should be enough to do the job. If you are not as steady, as I am not anymore, get a kid, preferable a teenager to help. They have better visual acuity and coordination. After you get the cracks filled in, leave it dry for a week, then, up to you what to do next. You can clean off the rest of the cabinet and spray the whole thing, or just touch up the finish with a little poly, again with a very small brush. Let dry for another week at least, and buff out any irregularites with a little pumice. All is reversable in case your expectations are not met. 999 other ways to do it.
Cracked veneer suggestions - by jontz - 03-06-2013, 03:25 PM
RE: Cracked veneer suggestions - by codefox1 - 03-06-2013, 03:42 PM
RE: Cracked veneer suggestions - by jontz - 03-07-2013, 08:59 AM
RE: Cracked veneer suggestions - by Arran - 03-08-2013, 03:13 AM
RE: Cracked veneer suggestions - by Phlogiston - 03-08-2013, 04:06 AM
RE: Cracked veneer suggestions - by jontz - 03-08-2013, 01:57 PM
RE: Cracked veneer suggestions - by Arran - 03-09-2013, 04:20 PM
