Philco 650 Rectifier tube bright!
Is the filaments bright or are the plates of the 80 glowing?
If its the filaments then I would check that your getting 5v on the filaments from the power trans. Did the power trans ohm out ok?
If its the plates glowing, then you got a short or something down stream that is pulling major current. Shorted E-cap?
The 83 tube is different not only does the filaments pull more current at 3amps (80 only 2amps) but the 83 is a mercury vapor rectifier.
-Keith
Philco 650 Rectifier tube bright! - by ewalters - 03-20-2013, 07:42 PM
RE: Philco 650 Rectifier tube bright! - by ipwizard - 03-22-2013, 12:03 PM
RE: Philco 650 Rectifier tube bright! - by morzh - 03-22-2013, 07:53 PM
RE: Philco 650 Rectifier tube bright! - by morzh - 03-23-2013, 02:05 PM
