  • 1 Vote(s) - 2 Average
1936 Philco 645
the chassis[Image: http://i1281.photobucket.com/albums/a508...451b8f.jpg]
1936 Philco 645 - by Ronin61 - 03-23-2013, 09:33 PM
RE: 1936 Philco 645 - by morzh - 03-23-2013, 10:48 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 07:58 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 10:05 AM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 01:21 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 01:38 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 01:39 PM
RE: 1936 Philco 645 - by Ronin61 - 03-24-2013, 01:41 PM
RE: 1936 Philco 645 - by 7estatdef - 03-24-2013, 03:06 PM
RE: 1936 Philco 645 - by Ronin61 - 03-26-2013, 03:13 PM
RE: 1936 Philco 645 - by 7estatdef - 03-27-2013, 07:38 AM
RE: 1936 Philco 645 - by morzh - 03-27-2013, 11:15 AM
RE: 1936 Philco 645 - by codefox1 - 03-28-2013, 03:34 AM
RE: 1936 Philco 645 - by Ronin61 - 04-07-2013, 08:30 PM
RE: 1936 Philco 645 - by 7estatdef - 04-10-2013, 05:27 PM
RE: 1936 Philco 645 - by Ronin61 - 04-11-2013, 03:58 PM
RE: 1936 Philco 645 - by Ronin61 - 04-22-2013, 09:57 AM
RE: 1936 Philco 645 - by 7estatdef - 04-22-2013, 04:13 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 04:57 PM
RE: 1936 Philco 645 - by Mondial - 02-02-2014, 05:15 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 05:32 PM
RE: 1936 Philco 645 - by Winky Dink - 02-02-2014, 10:20 PM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 12:07 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 02:43 AM
RE: 1936 Philco 645 - by Mondial - 02-03-2014, 08:24 AM
RE: 1936 Philco 645 - by Ron Ramirez - 02-03-2014, 10:27 AM
RE: 1936 Philco 645 - by Winky Dink - 02-03-2014, 06:35 PM
RE: 1936 Philco 645 - by Winky Dink - 02-04-2014, 12:00 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 09:10 AM
RE: 1936 Philco 645 - by codefox1 - 03-24-2014, 09:52 AM
RE: 1936 Philco 645 - by Winky Dink - 03-24-2014, 10:41 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
