03-30-2013, 07:08 AM
Morzh, what frequencies do you have on your dial scale?
If you have 52 to 150 in large numbers plus 1.5 to 4.0 in small numbers above that, then it is an 18 Code 121.
If you have 53 to 170 in large numbers and no other numbers, then it should be an 18 Code 124 (AM only).
If you have 54 to 170 on the lower of two scales plus 4.2 to 12 on the upper scale, both sets of numbers the same size, then you have a 118.
