  • 1 Vote(s) - 5 Average
Repurpose a Philco
You would make many of us happy if you keep the radio intact. As was suggested, you might sell it if you can and use the money to purchase something to hold your components.
Repurpose a Philco - by mis4tun81 - 04-09-2013, 11:31 AM
RE: Repurpose a Philco - by jerryhawthorne - 04-09-2013, 04:55 PM
RE: Repurpose a Philco - by w4rtc - 04-09-2013, 05:10 PM
RE: Repurpose a Philco - by Doug Houston - 04-09-2013, 06:24 PM
RE: Repurpose a Philco - by Arran - 04-09-2013, 06:31 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 07:39 PM
RE: Repurpose a Philco - by shaler78 - 04-09-2013, 08:09 PM
RE: Repurpose a Philco - by chris25260880 - 04-09-2013, 11:40 PM
RE: Repurpose a Philco - by codefox1 - 04-10-2013, 09:27 AM
RE: Repurpose a Philco - by PhilcoMike - 04-10-2013, 10:23 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 10:40 AM
RE: Repurpose a Philco - by Art Hoch - 04-10-2013, 11:09 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 11:19 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 11:21 AM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 11:26 AM
RE: Repurpose a Philco - by Ron Ramirez - 04-10-2013, 12:38 PM
RE: Repurpose a Philco - by mis4tun81 - 04-10-2013, 02:55 PM
RE: Repurpose a Philco - by Gene Pederson - 04-10-2013, 03:15 PM
RE: Repurpose a Philco - by shaler78 - 04-10-2013, 03:41 PM
RE: Repurpose a Philco - by Phlogiston - 04-10-2013, 06:49 PM
RE: Repurpose a Philco - by TimC - 04-10-2013, 08:10 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 08:38 PM
RE: Repurpose a Philco - by GarySP - 04-10-2013, 09:03 PM
RE: Repurpose a Philco - by Arran - 04-10-2013, 09:59 PM
RE: Repurpose a Philco - by gary rabbitt - 04-11-2013, 02:56 PM
RE: Repurpose a Philco - by DeckApe - 04-13-2013, 09:55 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
