How many Philco 38-116 radios are out there?
John, the 38-116 seems to be fussy about the 6A8G oscillator tube. On mine, the tube was a bit weak, and the increased current (due to lower grid voltage) pulled the screen voltage down lower as the dial was tuned lower. I have one in mine which works better than the others which I tried, but I am scouting around for a couple of NOS 6A8G tubes for it.
Tim KA3JRT
RE: How many Philco 38-116 radios are out there? - by Tim Tress - 06-21-2013, 01:15 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4799 online users. [Complete List]
» 2 Member(s) | 4797 Guest(s)
