07-04-2013, 10:13 AM
Hi;
My best guess, is that You are missing or have an open on one of the Coils.. The only way to know for sure is to ohm from each pin on the coil to where it is connected to and find that on the schematic or follow the wires and find where all the connections go.. Make Your own mini schematic and compare that to what the Schematic shows.. That should then make it perfectly clear where you should have a coil connection.. It looks like the lower coil connection is broken.. As you should have three coils and you only have two..
THANK YOU Marty
THANK YOU Marty
