1939 model 39-30
I've got a 39-30 as well. I have seen some 39-30's with only 1 tube shield, on the 75 tube. For whatever reason, my radio has provisions for two tube shields, on the 75 and the 37. But, when I got it, it only came with only 1 actual tube shield installed, on the 75. Could that be part of your problem?
Tom
1939 model 39-30 - by NostalgiaRadioTime - 09-13-2013, 11:47 PM
RE: 1939 model 39-30 - by Radioroslyn - 09-14-2013, 05:54 AM
RE: 1939 model 39-30 - by Bill Kinghorn - 09-14-2013, 09:42 AM
RE: 1939 model 39-30 - by Jamie - 09-14-2013, 01:40 PM
RE: 1939 model 39-30 - by Tom Hamilton - 09-20-2013, 10:29 AM
RE: 1939 model 39-30 - by TA Forbes - 09-20-2013, 12:14 PM
RE: 1939 model 39-30 - by TA Forbes - 09-20-2013, 12:15 PM
RE: 1939 model 39-30 - by NostalgiaRadioTime - 09-20-2013, 12:45 PM
RE: 1939 model 39-30 - by wa2ise - 09-20-2013, 03:30 PM
RE: 1939 model 39-30 - by wireless - 09-21-2013, 04:45 PM
RE: 1939 model 39-30 - by NostalgiaRadioTime - 09-21-2013, 08:45 PM
RE: 1939 model 39-30 - by NostalgiaRadioTime - 09-21-2013, 08:49 PM
RE: 1939 model 39-30 - by Electrothaumaturgist - 09-21-2013, 09:57 PM
RE: 1939 model 39-30 - by Arran - 09-21-2013, 10:00 PM
RE: 1939 model 39-30 - by Eric Adams - 09-22-2013, 10:23 AM
RE: 1939 model 39-30 - by PhilcoJohn - 09-26-2013, 07:01 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
