The Green Weenie 1936 116X
Ew who could even like the paint color Icon_thumbdown
The Green Weenie 1936 116X - by Gene Pederson - 09-26-2013, 03:22 PM
RE: The Green Weenie 1936 116X - by Art Hoch - 09-26-2013, 03:31 PM
RE: The Green Weenie 1936 116X - by Chuck Schwark - 09-26-2013, 04:00 PM
RE: The Green Weenie 1936 116X - by sam - 09-26-2013, 06:07 PM
RE: The Green Weenie 1936 116X - by Jayce - 09-26-2013, 06:12 PM
RE: The Green Weenie 1936 116X - by PhilcoJohn - 09-26-2013, 06:32 PM
RE: The Green Weenie 1936 116X - by Gene Pederson - 09-26-2013, 07:18 PM
RE: The Green Weenie 1936 116X - by Jamie - 09-27-2013, 04:20 AM
RE: The Green Weenie 1936 116X - by audiomagnate - 09-27-2013, 07:48 AM
RE: The Green Weenie 1936 116X - by TA Forbes - 09-27-2013, 01:41 PM
RE: The Green Weenie 1936 116X - by codefox1 - 09-27-2013, 04:47 PM
RE: The Green Weenie 1936 116X - by marty - 09-27-2013, 05:25 PM
RE: The Green Weenie 1936 116X - by Eric T - 09-28-2013, 07:23 AM
RE: The Green Weenie 1936 116X - by Radioroslyn - 09-28-2013, 05:30 PM
RE: The Green Weenie 1936 116X - by audiomagnate - 09-28-2013, 08:22 PM
RE: The Green Weenie 1936 116X - by Arran - 09-28-2013, 10:04 PM
RE: The Green Weenie 1936 116X - by Chuck Schwark - 09-30-2013, 09:25 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
