It's Raining Philcos Around Here!
As a teenager, I had the Farrah poster...only because I won it at the county fair. I thought she was OK but greatly overrated. Back then I thought Linda Ronstadt was a major hottie.
Olivia Newton-John? She had a beautiful face but no figure...Olivia is remarkably well-preserved now for her age...hard to believe she's 65 now...
Geez, from raining Philcos to reigning beauty queens in one topic. <--- Hey, I coined a Michael Savage-ism! Icon_wink
RE: It's Raining Philcos Around Here! - by GarySP - 03-28-2013, 08:28 PM
RE: It's Raining Philcos Around Here! - by morzh - 08-01-2013, 11:11 AM
RE: It's Raining Philcos Around Here! - by marty - 09-24-2013, 06:24 PM
RE: It's Raining Philcos Around Here! - by sam - 09-24-2013, 10:18 PM
RE: It's Raining Philcos Around Here! - by marty - 09-24-2013, 10:22 PM
RE: It's Raining Philcos Around Here! - by Arran - 09-26-2013, 12:32 AM
RE: It's Raining Philcos Around Here! - by Jamie - 09-26-2013, 01:37 PM
RE: It's Raining Philcos Around Here! - by Ron Ramirez - 09-27-2013, 08:39 AM
RE: It's Raining Philcos Around Here! - by kj0002 - 09-27-2013, 05:05 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2801 online users. [Complete List]
» 2 Member(s) | 2799 Guest(s)
