Finished my 37-610 Today...
Really nice work. Is the grille cloth original or did you find a source for repro cloth in that rib pattern?
Finished my 37-610 Today... - by Jamie - 09-28-2013, 08:44 PM
RE: Finished my 37-610 Today... - by VntgRads - 09-28-2013, 08:53 PM
RE: Finished my 37-610 Today... - by sam - 09-28-2013, 09:20 PM
RE: Finished my 37-610 Today... - by PhilcoJohn - 09-29-2013, 07:55 AM
RE: Finished my 37-610 Today... - by marty - 09-29-2013, 08:15 AM
RE: Finished my 37-610 Today... - by Jamie - 09-29-2013, 08:22 AM
RE: Finished my 37-610 Today... - by kj0002 - 09-29-2013, 02:24 PM
RE: Finished my 37-610 Today... - by Ron Ramirez - 09-29-2013, 07:02 PM
RE: Finished my 37-610 Today... - by Jamie - 09-29-2013, 07:53 PM
RE: Finished my 37-610 Today... - by Jamie - 09-29-2013, 08:09 PM
RE: Finished my 37-610 Today... - by Mondial - 09-29-2013, 09:06 PM
RE: Finished my 37-610 Today... - by Jamie - 09-29-2013, 09:29 PM
RE: Finished my 37-610 Today... - by KCMike - 09-29-2013, 09:55 PM
RE: Finished my 37-610 Today... - by kj0002 - 10-02-2013, 08:33 PM
RE: Finished my 37-610 Today... - by Tom Hamilton - 10-07-2013, 10:52 AM
RE: Finished my 37-610 Today... - by Jamie - 10-07-2013, 12:17 PM
RE: Finished my 37-610 Today... - by wireless - 10-07-2013, 03:02 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5296 online users. [Complete List]
» 1 Member(s) | 5295 Guest(s)
