A walk down memory lane
Nice,
The last time i went to Cederburg, probably five years ago, I came home with a Philco 60. It was in terrible shape, Painted white ,delaminating, speaker missing and all the usual bad coils. That one looks real good.
A walk down memory lane - by 37silverstreak - 10-06-2013, 03:58 PM
RE: A walk down memory lane - by exray - 10-06-2013, 08:17 PM
RE: A walk down memory lane - by VntgRads - 10-07-2013, 12:11 AM
RE: A walk down memory lane - by marty - 10-07-2013, 08:47 AM
RE: A walk down memory lane - by Art Hoch - 10-07-2013, 10:18 AM
RE: A walk down memory lane - by TA Forbes - 10-07-2013, 03:08 PM
RE: A walk down memory lane - by 37silverstreak - 10-11-2013, 10:44 PM
RE: A walk down memory lane - by Ron Ramirez - 10-12-2013, 07:59 PM
RE: A walk down memory lane - by Paul Knaack - 10-12-2013, 09:34 PM
RE: A walk down memory lane - by PhilcoJohn - 10-13-2013, 07:15 AM
RE: A walk down memory lane - by 37silverstreak - 10-13-2013, 09:12 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4101 online users. [Complete List]
» 2 Member(s) | 4099 Guest(s)
