Philco 48-1274 No A.M or F.M. signal.
Hey guys i am new to the forum and may need someone with exp in this particular console. I paid 60 for it and it was completely non-functional. I now have power and the tubes light up as well as bulbs but aside from static I have absolutely nothing else. The motor for the presets works as well. So instead of being an idiot and digging in I want to see if anyone has had or may know the steps to get her back up and going. Please make sure you imply if it is an (opinion) or an issue you (directly) encountered. I am currently and proud to say the least that im officially hooked on the phonographs and have 2 so far. Thank you guys for letting me join your forum and look forward to these discussions Icon_thumbup
Philco 48-1274 No A.M or F.M. signal. - by Hick-a-billy - 10-13-2013, 11:19 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5311 online users. [Complete List]
» 1 Member(s) | 5310 Guest(s)
