My Philco 91X, no longer ignored.
The 91 is a good playing set! I had one years ago it was a chairside with a big old separate speaker cabinet. In the cabinet was the dual speakers like your set. At the time I wished that it had some SW coverage.
My Philco 91X, no longer ignored. - by Jayce - 10-22-2013, 06:32 PM
RE: My Philco 91X, no longer ignored. - by Radioroslyn - 10-22-2013, 07:04 PM
RE: My Philco 91X, no longer ignored. - by KCMike - 10-22-2013, 07:40 PM
RE: My Philco 91X, no longer ignored. - by Jayce - 10-22-2013, 08:44 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4740 online users. [Complete List]
» 2 Member(s) | 4738 Guest(s)
