10-24-2013, 06:02 PM
LAS, yes, I tested all the tubes. The 80 tested out good with no shorts showing on my tester. I could search the tube stash and try a different one. Speaking of a short plate to filament, check out this photo...
The brown wire is running to plate. The black wire is filament. The brown wire is pinned up against the filament terminal by the black wire. You can see that I pulled it forward about 1/2 inch to see if the covering had worn off. I couldn't detect a short, but we are both on the same page.
