Frequency counter
Inexpensive modern handheld but pretty good digital frequency counters are available at very low cost. and venerable old ones also pretty cheap pretty much. Have an old model I use to true up my ancient Eico signal generator when aligning old radio sets. Dunno about reliability on really higher harmonics. Anyway, nice to know if generator is putting out a peak prety much on the frequency you read on the schematic to perform alignment. Beyond that, a good analog meter is a best friend for output for a modulated signal, sadly, much better than my ears.
Frequency counter - by fields 100 - 01-19-2014, 02:49 PM
RE: Frequency counter - by codefox1 - 01-19-2014, 04:39 PM
RE: Frequency counter - by morzh - 01-19-2014, 05:06 PM
RE: Frequency counter - by Warren - 01-19-2014, 11:51 PM
RE: Frequency counter - by gregb - 01-20-2014, 09:51 AM
RE: Frequency counter - by PAradiogeek - 01-20-2014, 06:04 PM
RE: Frequency counter - by Warren - 01-20-2014, 11:51 PM
RE: Frequency counter - by jontz - 01-22-2014, 05:45 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4287 online users. [Complete List]
» 1 Member(s) | 4286 Guest(s)
