Is this cabinet Restorable?
OK, here's one for the cabinet folks.
http://elmira.craigslist.org/atq/4294942467.html
I think I already know the answer but any comments?
Herb S.
Ithaca NY
Is this cabinet Restorable? - by hsusmann - 01-21-2014, 07:02 PM
RE: Is this cabinet Restorable? - by tab10672 - 01-21-2014, 07:07 PM
RE: Is this cabinet Restorable? - by morzh - 01-21-2014, 07:12 PM
RE: Is this cabinet Restorable? - by OldRestorer - 01-21-2014, 07:26 PM
RE: Is this cabinet Restorable? - by TA Forbes - 01-21-2014, 07:45 PM
RE: Is this cabinet Restorable? - by hsusmann - 01-21-2014, 08:46 PM
RE: Is this cabinet Restorable? - by OldRestorer - 01-21-2014, 08:58 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2358 online users. [Complete List]
» 2 Member(s) | 2356 Guest(s)
