  • 1 Vote(s) - 5 Average
Philco 70 restoration attempt - singing now.
Looking nice,
I haven't tried the hot glue but with the Halson I do want to restuff those 2 big cardboard Ecap tubes.
You need more pictures so I understand it better, plus I like pictures anyway. Icon_biggrin
Cant wait till its done! keep on going and keep us updated.
RE: Philco 70 restoration attempt. - by morzh - 01-24-2014, 09:53 PM
RE: Philco 70 restoration attempt. - by morzh - 01-24-2014, 11:00 PM
RE: Philco 70 restoration attempt. - by morzh - 01-24-2014, 11:59 PM
RE: Philco 70 restoration attempt. - by Jamesm - 01-25-2014, 10:57 AM
RE: Philco 70 restoration attempt. - by gregb - 01-25-2014, 02:50 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 06:28 PM
RE: Philco 70 restoration attempt. - by morzh - 01-25-2014, 08:13 PM
RE: Philco 70 restoration attempt. - by Mondial - 01-25-2014, 11:28 PM
RE: Philco 70 restoration attempt. - by gregb - 01-25-2014, 11:40 PM
RE: Philco 70 restoration attempt. - by morzh - 01-26-2014, 01:57 PM
RE: Philco 70 restoration attempt. - by Raleigh - 01-27-2014, 01:12 PM
RE: Philco 70 restoration attempt. - by morzh - 01-27-2014, 01:46 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 09:10 PM
RE: Philco 70 restoration attempt. - by morzh - 01-31-2014, 09:11 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-01-2014, 12:20 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 12:53 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 10:27 PM
RE: Philco 70 restoration attempt. - by morzh - 02-01-2014, 10:39 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 08:12 PM
RE: Philco 70 restoration attempt. - by morzh - 02-02-2014, 08:25 PM
RE: Philco 70 restoration attempt. - by morzh - 02-03-2014, 08:32 PM
RE: Philco 70 restoration attempt. - by morzh - 02-05-2014, 12:04 PM
RE: Philco 70 restoration attempt. - by morzh - 02-06-2014, 08:03 PM
RE: Philco 70 restoration attempt. - by OldRestorer - 02-07-2014, 03:37 PM
RE: Philco 70 restoration attempt. - by morzh - 02-07-2014, 03:52 PM
RE: Philco 70 restoration attempt. - by murf - 02-08-2014, 02:15 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 02:41 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-08-2014, 02:41 PM
RE: Philco 70 restoration attempt. - by morzh - 02-08-2014, 02:49 PM
RE: Philco 70 restoration attempt. - by morzh - 02-10-2014, 09:37 PM
RE: Philco 70 restoration attempt. - by TV MAN - 02-11-2014, 11:16 AM
RE: Philco 70 restoration attempt. - by morzh - 02-11-2014, 11:27 AM
RE: Philco 70 restoration attempt. - by morzh - 02-13-2014, 08:48 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3953 online users. [Complete List]
» 1 Member(s) | 3952 Guest(s)
