  • 1 Vote(s) - 1 Average
Not receiving all stations on AM
Not sure how bad output transformer causes static, but it is good you found it. It probably has one half that is baked and so it is 1) might be bringing down the power supply voltage, 2) killing its tube in the process.
Make sure your output PP transformer is close to the one you had before, otherwise though it will probably work without damaging anything you will not get the proper sound/power/quality levels.
Not receiving all stations on AM - by Warren - 02-25-2014, 01:38 PM
RE: Not recieving all stations on AM - by Warren - 02-25-2014, 08:40 PM
RE: Not receiving all stations on AM - by Warren - 02-25-2014, 11:28 PM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 07:59 AM
RE: Not receiving all stations on AM - by Mondial - 02-26-2014, 10:36 AM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 02:00 PM
RE: Not receiving all stations on AM - by Jamie - 02-26-2014, 10:28 PM
RE: Not receiving all stations on AM - by Warren - 02-26-2014, 11:58 PM
RE: Not receiving all stations on AM - by Mondial - 02-27-2014, 10:07 AM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 05:21 PM
RE: Not receiving all stations on AM - by exray - 02-27-2014, 05:36 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 10:05 PM
RE: Not receiving all stations on AM - by morzh - 02-27-2014, 10:17 PM
RE: Not receiving all stations on AM - by Warren - 02-27-2014, 11:26 PM
RE: Not receiving all stations on AM - by Mondial - 02-28-2014, 10:38 AM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 10:53 AM
RE: Not receiving all stations on AM - by Warren - 02-28-2014, 02:03 PM
RE: Not receiving all stations on AM - by morzh - 02-28-2014, 02:43 PM
RE: Not receiving all stations on AM - by Warren - 03-01-2014, 07:55 PM
RE: Not receiving all stations on AM - by Warren - 03-02-2014, 11:26 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 08:41 AM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 01:50 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 02:35 PM
RE: Not receiving all stations on AM - by Warren - 03-03-2014, 03:15 PM
RE: Not receiving all stations on AM - by morzh - 03-03-2014, 03:41 PM
RE: Not receiving all stations on AM - by Warren - 03-04-2014, 02:18 PM
RE: Not receiving all stations on AM - by Warren - 03-08-2014, 11:31 PM
RE: Not receiving all stations on AM - by Warren - 03-29-2014, 10:53 PM
RE: Not receiving all stations on AM - by Warren - 03-31-2014, 12:39 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
